【C#】利用现有的Windows远程桌面功能,通过P2P连接直接访问对方的远程桌面服务
2025年6月23日 17:26 本文热度 2830
解决方案设计
架构概述
关键组件
  • 协调服务器:交换客户端端点信息
  • P2P客户端:建立直接连接并设置端口转发
  • Windows远程桌面:使用标准RDP协议
完整代码实现
1. 协调服务器 (P2PCoordinator.cs)
using System.Collections.Generic;
using System.Net;
using System.Net.Sockets;
using System.Text;
using System.Threading;
class P2PCoordinator
    private const int ServerPort = 11000;
    private TcpListener _tcpListener;
    private readonly Dictionary<string, IPEndPoint> _tcpEndpoints = new();
    private readonly Dictionary<string, TcpClient> _tcpConnections = new();
    private readonly object _lock = new object();
    private bool _isRunning = true;
    public P2PCoordinator()
            _tcpListener = new TcpListener(IPAddress.Any, ServerPort);
            Console.WriteLine($"P2P协调服务器启动,监听端口: {ServerPort}");
        catch (Exception ex)
            Console.WriteLine($"服务器初始化失败: {ex.Message}");
            Environment.Exit(1);
    public void Start()
        new Thread(ListenTcp).Start();
        Console.WriteLine("服务器运行中. 按任意键停止...");
        Console.ReadKey();
        Stop();
    private void ListenTcp()
            _tcpListener.Start();
            Console.WriteLine("TCP监听已启动");
            while (_isRunning)
                TcpClient client = _tcpListener.AcceptTcpClient();
                new Thread(() => HandleTcpClient(client)).Start();
            if (_isRunning) Console.WriteLine($"TCP监听错误: {ex.Message}");
    private void HandleTcpClient(TcpClient client)
        string clientId = null;
            NetworkStream stream = client.GetStream();
            byte[] buffer = new byte[1024];
            int bytesRead = stream.Read(buffer, 0, buffer.Length);
            if (bytesRead == 0) return;
            string message = Encoding.ASCII.GetString(buffer, 0, bytesRead);
            string[] parts = message.Split(':');
            if (parts.Length < 2) return;
            string command = parts[0];
            clientId = parts[1];
            var clientEP = (IPEndPoint)client.Client.RemoteEndPoint;
            Console.WriteLine($"[TCP] {clientId} 连接: {clientEP}");
            lock (_lock)
                if (command == "REGISTER")
                    _tcpEndpoints[clientId] = clientEP;
                    _tcpConnections[clientId] = client;
                    Console.WriteLine($"[注册] {clientId} -> {clientEP}");
                    SendTcpResponse(client, "REGISTERED");
                else if (command == "CONNECT" && parts.Length > 2)
                    string targetId = parts[2];
                    Console.WriteLine($"[连接请求] {clientId} -> {targetId}");
                    HandleConnectionRequest(clientId, targetId);
            // 处理后续消息
            while (_isRunning)
                if (bytesRead == 0) break;
                command = parts[0];
                if (command == "HEARTBEAT")
                    // 心跳检测
                    SendTcpResponse(client, "HEARTBEAT_ACK");
            Console.WriteLine($"处理TCP客户端错误: {ex.Message}");
        finally
            if (clientId != null)
                lock (_lock)
                    _tcpConnections.Remove(clientId);
                    _tcpEndpoints.Remove(clientId);
            client.Close();
    private void HandleConnectionRequest(string fromClient, string toClient)
        lock (_lock)
            if (!_tcpConnections.ContainsKey(fromClient))
                Console.WriteLine($"[错误] 源客户端未连接: {fromClient}");
                return;
            if (!_tcpConnections.ContainsKey(toClient))
                SendTcpResponse(_tcpConnections[fromClient], "ERROR:目标客户端未连接");
                Console.WriteLine($"[错误] 目标客户端未连接: {toClient}");
                return;
            if (!_tcpEndpoints.TryGetValue(fromClient, out IPEndPoint fromEp) ||
                !_tcpEndpoints.TryGetValue(toClient, out IPEndPoint toEp))
                SendTcpResponse(_tcpConnections[fromClient], "ERROR:端点信息不完整");
                Console.WriteLine($"[错误] 端点信息不完整: {fromClient} -> {toClient}");
                return;
            // 交换端点信息
            string fromMessage = $"PEER_INFO:{toClient}:{toEp.Address}:{toEp.Port}";
            string toMessage = $"PEER_INFO:{fromClient}:{fromEp.Address}:{fromEp.Port}";
            SendTcpResponse(_tcpConnections[fromClient], fromMessage);
            SendTcpResponse(_tcpConnections[toClient], toMessage);
            Console.WriteLine($"[端点交换] {fromClient} <-> {toClient}");
            Console.WriteLine($"  {fromEp} <-> {toEp}");
    private void SendTcpResponse(TcpClient client, string message)
            if (client.Connected)
                byte[] data = Encoding.ASCII.GetBytes(message);
                stream.Write(data, 0, data.Length);
            Console.WriteLine($"发送TCP响应错误: {ex.Message}");
    private void Stop()
        Console.WriteLine("停止服务器...");
        _isRunning = false;
            lock (_lock)
                foreach (var client in _tcpConnections.Values)
                    try { client.Close(); } catch { }
                _tcpConnections.Clear();
                _tcpEndpoints.Clear();
            _tcpListener.Stop();
            Console.WriteLine("服务器已停止");
            Console.WriteLine($"停止服务器错误: {ex.Message}");
        Console.Title = "P2P协调服务器";
        Console.WriteLine("=== P2P协调服务器 ===");
        Console.WriteLine("用于远程桌面直连");
        Console.WriteLine("端口: " + ServerPort);
        Console.WriteLine(new string('=', 50));
        var server = new P2PCoordinator();
        server.Start();
2. P2P客户端 (P2PRdpClient.cs)
using System.Net;
using System.Text;
using System.Runtime.InteropServices;
class P2PRdpClient
    // 配置参数
    private readonly string _serverIp;
    private readonly int _serverPort;
    private readonly string _clientId;
    // 网络组件
    private TcpClient _tcpServerConnection;
    private NetworkStream _tcpStream;
    // 状态变量
    private IPEndPoint _peerEp;
    public P2PRdpClient(string serverIp, int serverPort, string clientId)
        _serverIp = serverIp;
        _serverPort = serverPort;
        _clientId = clientId;
    public void Start()
        ConnectToServer();
        new Thread(Heartbeat).Start();
        Console.WriteLine("命令:");
        Console.WriteLine("  connect [目标ID] - 请求P2P连接");
        Console.WriteLine("  rdp [目标IP] [端口] - 启动远程桌面");
        Console.WriteLine("  exit - 退出程序");
        while (_isRunning)
            Console.Write("> ");
            string input = Console.ReadLine();
            if (string.IsNullOrEmpty(input)) continue;
            string[] parts = input.Split(' ');
            string command = parts[0].ToLower();
            switch (command)
                case "connect":
                    if (parts.Length > 1) RequestConnection(parts[1]);
                    else Console.WriteLine("缺少目标ID");
                    break;
                case "rdp":
                    if (parts.Length > 2) StartRemoteDesktop(parts[1], int.Parse(parts[2]));
                    else Console.WriteLine("缺少IP或端口");
                    break;
                case "exit":
                    _isRunning = false;
                    break;
                default:
                    Console.WriteLine("未知命令");
                    break;
        // 清理资源
        _isRunning = false;
        _tcpServerConnection?.Close();
    #region 服务器通信
    private void ConnectToServer()
            _tcpServerConnection = new TcpClient(_serverIp, _serverPort);
            _tcpStream = _tcpServerConnection.GetStream();
            Console.WriteLine("已连接到协调服务器");
            string registerMsg = $"REGISTER:{_clientId}";
            byte[] data = Encoding.ASCII.GetBytes(registerMsg);
            _tcpStream.Write(data, 0, data.Length);
            new Thread(ReceiveFromServer).Start();
            Console.WriteLine($"连接服务器失败: {ex.Message}");
    private void RequestConnection(string targetId)
        string message = $"CONNECT:{_clientId}:{targetId}";
    private void ReceiveFromServer()
            while (_isRunning)
                int bytesRead = _tcpStream.Read(buffer, 0, buffer.Length);
                Console.WriteLine($"收到服务器消息: {message}");
                if (parts[0] == "PEER_INFO")
                    HandlePeerInfo(parts);
                else if (parts[0] == "ERROR")
                    Console.WriteLine($"服务器错误: {message.Substring(6)}");
            Console.WriteLine($"接收服务器消息错误: {ex.Message}");
    private void HandlePeerInfo(string[] parts)
        if (parts.Length < 4) return;
        string peerId = parts[1];
        string ip = parts[2];
        int port = int.Parse(parts[3]);
        _peerEp = new IPEndPoint(IPAddress.Parse(ip), port);
        Console.WriteLine($"目标端点: {_peerEp}");
        Console.WriteLine($"您可以使用以下命令启动远程桌面:");
        Console.WriteLine($"  rdp {ip} {port}");
    #endregion
    #region 远程桌面功能
    private void StartRemoteDesktop(string ip, int port)
            Console.WriteLine($"正在启动远程桌面连接: {ip}:{port}");
            // 使用mstsc.exe连接远程桌面
            ProcessStartInfo startInfo = new ProcessStartInfo
                FileName = "mstsc.exe",
                Arguments = $"/v:{ip}:{port}",
                UseShellExecute = false
            Process.Start(startInfo);
            Console.WriteLine("远程桌面已启动");
            Console.WriteLine($"启动远程桌面失败: {ex.Message}");
    #endregion
    #region 辅助功能
    private void Heartbeat()
        while (_isRunning)
                Thread.Sleep(30000);
                if (_tcpServerConnection.Connected)
                    byte[] data = Encoding.ASCII.GetBytes("HEARTBEAT");
                Console.WriteLine($"发送心跳失败: {ex.Message}");
    #endregion
        if (args.Length < 2)
            Console.WriteLine("用法: P2PRdpClient.exe [服务器IP] [客户端ID]");
            return;
        string serverIp = args[0];
        string clientId = args[1];
        var client = new P2PRdpClient(serverIp, 11000, clientId);
        client.Start();
使用流程
1. 部署协调服务器
P2PCoordinator.exe
2. 启动被控端客户端
P2PRdpClient.exe [服务器IP] ControlledPC
3. 启动控制端客户端
P2PRdpClient.exe [服务器IP] ControlPC
4. 建立P2P连接
在控制端输入:
connect ControlledPC
5. 启动远程桌面
在控制端输入:
rdp [被控端IP] [被控端端口]
技术实现细节
1. 端口转发方案(被控端)
要让远程桌面通过P2P连接工作,需要在被控端设置端口转发。以下是使用netsh设置端口转发的批处理脚本:
被控端设置端口转发 (setup_port_forward.bat):
@echo off
setlocal
REM 获取本机IP地址
for /f "tokens=14 delims= " %%i in ('ipconfig ^| findstr "IPv4"') do set local_ip=%%i
REM 设置端口转发 (需要管理员权限)
netsh interface portproxy add v4tov4 listenport=3389 listenaddress=%local_ip% connectport=3389 connectaddress=127.0.0.1
echo 端口转发已设置: %local_ip%:3389 -> 127.0.0.1:3389
echo 确保防火墙允许入站连接端口3389
pause
2. 防火墙配置(被控端)
允许远程桌面服务通过防火墙:
netsh advfirewall firewall add rule name="Remote Desktop" dir=in protocol=TCP localport=3389 action=allow
3. 完整工作流程
  1. 被控端准备:
    • 启用Windows远程桌面服务
    • 运行端口转发脚本(管理员权限)
    • 启动客户端:P2PRdpClient.exe server_ip ControlledPC
  2. 控制端操作:
    • 启动客户端:P2PRdpClient.exe server_ip ControlPC
    • 输入:connect ControlledPC
    • 获取被控端公网IP和端口
    • 输入:rdp [被控端IP] [被控端端口]
  3. 网络穿透:
    • 控制端直接连接到被控端的3389端口
    • 被控端的端口转发将流量转到127.0.0.1:3389
    • 建立标准RDP连接
4. 连接示意图
增强功能
1. 自动端口检测脚本
port_checker.ps1 (PowerShell):
param(
    [string]$serverIp,
    [string]$clientId
# 启动客户端
Start-Process -FilePath "P2PRdpClient.exe" -ArgumentList $serverIp, $clientId
# 等待连接建立
Start-Sleep -Seconds 10
# 自动检测监听的端口
$ports = @(3389, 3390, 3391) # 常用RDP端口
$ipAddress = (Test-Connection -ComputerName $env:COMPUTERNAME -Count 1).IPV4Address.IPAddressToString
foreach ($port in $ports) {
    try {
        $listener = [System.Net.Sockets.TcpListener]$port
        $listener.Start()
        $listener.Stop()
        Write-Host "端口 $port 可用"
        # 设置端口转发
        netsh interface portproxy add v4tov4 listenport=$port listenaddress=$ipAddress connectport=3389 connectaddress=127.0.0.1
        # 添加防火墙规则
        netsh advfirewall firewall add rule name="RDP_P2P_$port" dir=in action=allow protocol=TCP localport=$port
        Write-Host "已设置端口转发: ${ipAddress}:${port} -> 127.0.0.1:3389"
        break
    catch {
        Write-Host "端口 $port 已被占用"
2. NAT穿透优化
对于复杂NAT环境,可使用以下增强穿透技术:
// 在客户端中添加
private void EnhanceNatPenetration(IPEndPoint peerEp)
        // UDP打洞增强
        using (var udpClient = new UdpClient(0))
            for (int i = 0; i < 5; i++)
                byte[] data = Encoding.ASCII.GetBytes($"PUNCH:{_clientId}:{i}");
                udpClient.Send(data, data.Length, peerEp);
                Thread.Sleep(200);
        // TCP连接尝试
        using (var tcpClient = new TcpClient())
            tcpClient.Connect(peerEp);
            tcpClient.Close();
    catch
        // 忽略错误,主要目的是打洞
3. 连接测试工具
connection_tester.py:
import socket
import sys
def test_connection(ip, port):
    try:
        with socket.create_connection((ip, port), timeout=5) as sock:
            print(f"成功连接到 {ip}:{port}")
            return True
    except Exception as e:
        print(f"连接失败: {e}")
        return False
if __name__ == "__main__":
    if len(sys.argv) != 3:
        print("用法: connection_tester.py [IP] [端口]")
        sys.exit(1)
    test_connection(sys.argv[1], int(sys.argv[2]))
注意事项
  1. 防火墙配置:
    • 被控端需要开放RDP端口(默认3389)
    • 如果使用其他端口,需相应调整防火墙设置
  2. 网络要求:
    • 被控端需要允许入站RDP连接
    • 控制端需要出站访问协调服务器和P2P端口
  3. 安全建议:
    • 使用强密码保护远程桌面账户
    • 考虑使用VPN进行更安全的连接
    • 限制可连接IP地址范围
  4. 权限要求:
    • 端口转发脚本需要管理员权限
    • RDP服务需要启用
这个方案直接利用Windows内置的远程桌面功能,通过P2P连接实现直连,避免了在应用中重新实现远程桌面协议,既高效又可靠。
该文章在 2025/6/24 10:27:03 编辑过
2025年6月24日 10:37
C#实现混合P2P点对点直接连接方案(TCP + UDP),如果TCP连接失败则改用UDP连接[28]
  http://31815.oa22.cn
该评论在 2025/6/24 10:37:07 编辑过
